I`m a registered user but just installed the program for the first time, latest build I got from the website. After installation ist just doesn`t start but gives me an unhandled exception message, I copied it to the clipboard >
Version: SVCD2DVD 2.1
Build: 2.1.2308.33387
Type: System.ArgumentException
Source: System.Drawing
Message: Font 'Tahoma' doesn't support style 'Regular'.
InnerException:
StackTrace: at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
at x15b8b992d7de1dd3.xd7cf011d2fb4d963.x85601834555fb 7d5()
at x15b8b992d7de1dd3.xd7cf011d2fb4d963..ctor()
at x3284ccece41ee22b.x1793c29359b82430.x85601834555fb 7d5()
at x3284ccece41ee22b.x1793c29359b82430..ctor()
at x3284ccece41ee22b.x2f5590cb48bb0c53.x83f20715bdcc4 873(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x2f5590cb48bb0c53.xc447809891322 395(String[] xce8d8c7e3c2c2426)
I don`t have any other version of SVCD2DVD but would like to use it of course so what shall I do now ? Thanks for hints and answers.
merula
Edit: To make things clear, I paid the program but probably there will be a registration process later in it, I cannot know or handle this if the program doesn`t even start but this will not make any difference concerning this unhandled exception. .net 1.1 is installed of course, too.
This has happened before when the installed fonts have been corrupt. Drop me an email & I'll send you the non corrupted 'Tahoma' font.
Matshita BD UJ240AS doesn't work (not perform start of Disc-at-once)
By whenloverageswild in forum Authoring (Blu-ray)Replies: 5Last Post: 11th Nov 2011, 02:08 -
svcd2dvd doesn't start
By mapache in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Feb 2008, 08:10 -
FLV conversion: playback doesn't start from 0 seconds.
By silentsteps in forum Video ConversionReplies: 0Last Post: 1st Dec 2007, 16:59 -
picture doesn't fill TV screen - let me back up and start over.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 21:48 -
SVCD2DVD error on start up 'Application has generated an exception...'
By Turnstyle in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 16th May 2007, 03:53
